make a custom character with Affinity Designer2 -Head creating and export
Replacing hair
  1. Extend the group RLImage Head>FrontHair>FrontHairReplace
  2. Replace the Front hair sprite in the “FrontHairReplace” group.
The back hair sprite follows the same method as the front hair.
Face, ears, front hair, back hair, eyebrows, and mouth all follow the same procedure.
Replacing eyes
1. Extend LEye >Normal, there are three groups there.
Extend them, and replace the sprites as the following picture illustrated.
Please note:
  • For Iris Replace, please use only one image element, do not use group elements as it may cause unreadability.
Replacing Nose
First, expand these three folders.
The nose has three angles: Center, left, and center-right.
Make sure to paste them in the correct positions.
Export SVG
Make sure to export according to this setting.
Enter Composer Mode, click on this icon Import SVG, and import the head.
Done.
Other Common Issues
Q: After importing, why isn’t the front hair showing?
A: First, open the 360 Head Creator, then adjust the Layer.
