Project freezing & crashing
1. Preview render setting:
With iClone and Character Creator, in the upper toolbar, you can select the Quick Mode preview quality to keep the performance.
High quality will completely render the material of viewport. The other options will reduce the rendering preview of the material. Refer to this manual page for more info.
2. Lower the Max Texture Size in Preferences:
Note: Reducing Texture size can greatly improve real time editing speed without affecting the final output quality!
3. Monitor and balance your usage:
Press Ctrl + F to open the system information, observe the system resource usage, and observe whether the number of polygons is too many.
Note: High modulus may cause the project to freeze. It is recommended to download the low modulus version or use external software to perform polygon reduction processing.
4. Clean Temp Files:
Please try this temp file removal. Quit all running applications and try the following.
1. Type %Temp% on the Search box on the Task Bar and click the %Temp% folder in the search list.
2. This will take you to C:\Users\%USERNAME%\AppData\Local\Temp
3. Highlight and delete all the folders and files in the Temp folder (some may remain, this is normal).
4. Go to C:\Windows\Temp
5. Highlight and delete all the folders and files there.
6. Restart your computer.
* NOTE: The Local\Temp folder is a hidden folder and so may not appear. To view hidden files and folders, do the following:
1. Open the Control Panel and select “Appearance & Personalization”.
2. Click “Show Hidden File and Folders”.
3. On the View tab, under Hidden files and folders, click Show hidden files and folders.
You may want to specify a new location for your temp file. I keep mine on a separate drive, instead of my C drive. You can set it in the preferences.
For improving system performance, please refer to this page.
If the steps mentioned above still do not resolve your issue, please visit the Reallusion forum or contact our support team.
