In the following tutorial, this package will be used as an example.
https://www.reallusion.com/contentstore/pack/hq-modern-classic-interior
We’re going to animate opening door and drawer, here below is the breakdown:
1.First, select the door in Content Manager, press hotkey [F] to focus the door in viewport quickly. (See more about Hotkey)
2. Press Hotkey [W] for move, [E] for rotate. The pivot of prop can be edited via Modify panel > Attribute > Pivot section > Edit Pivot.
3. Select the keyframe in timeline, rotate the door to the position you want. Press Play and prop animation finished.
4. You can even bake the animation by using Collect Clip, see the manual here: https://manual.reallusion.com/iClone-8/Content/ENU/8.0/51-Animation-Timeline-Editing/Collect_Clip_Track.htm
