1 ) Import a character model.
Setting Up Toon Shader
2) In the “Visual” panel, enable “Toon Shader”.
After enabling the Toon Shader, you’ll get this result:
Adding Atomosphere
Click “Window > Content Manager”(or press F4).
Click “Stage > Atomosphere > Stylized > IBL Inferno” to set skylight.
Click on “Scene > Scene Collection > Sky”,then click on “Modify > Material”.
Change the sky texture to the one you prefer.
Adjust “Paint > Toon Level” to a color similar to the background.
Under “Visual > Toon Shader”, adjust “Normal Threshold” to 100 (%).
The end result:
Download the project here: tutorial.iProject
